ariejan
- Mar 29, 2019
I just upgraded a freshly installed 11.2-U2.1 installation to 11.2-U3. I'm now running into the issue that I cannot install plugins or create jails, as I get the following error message. It seems there is an issue with the on/off vs. yes/no boolean options here.
works fine.
Should this be reported as a bug? Or is something wrong with my install?
sudo iocage create -r 11.2-RELEASE -n myjail boot=on
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 200, in create_job
empty=empty
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 611, in create
clone=clone,
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_create.py", line 87, in create_jail
return self._create_jail(jail_uuid, location)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_create.py", line 412, in _create_jail
raise RuntimeError(f"***\n{err}\n***\n")
RuntimeError: ***
no is not a valid value for hostid_strict_check.
Value must be off or on
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run
await self.future
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 356, in __run_body
rv = await self.middleware._call_worker(self.serviceobj, self.method_name, *self.args, job={'id': self.id})
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1105, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1036, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1021, in run_in_executor
RuntimeError: ***
