Hi everyone!
Several months have passed with my 'new' build, getting accustomed to Truenas Core, and it's already time for some upgrades!
(hardware before all the upgrades)
I bought 3 additional Exos X16's, a Xeon-e 2244G, an X520 NIC and upgraded to 128GB ECC RAM.
The first to optimize the usable space in the pool and I added a hot spare.
(So i went from 3 data disks + 2 parity disks to 5 data, 2 parity disks and a hot spare. Transitioned using the hot spare flawlessly with the replication function!)
The second purely for Plex/transcoding purposes. (damn those prices are still high for these Xeons..
The third, 1GB recommended per TB storage, so bit the bullet there too
The last but not least on my 'nice to have list', is the X520 NIC.. as recommended here all over Truenas forum, which is giving me a headache at the moment..
I just can't get it to work.
So, both X520's (i have the exact same in my desktop running fine) were tested, interchanged, the wires checked, swapped trancievers, etc.. still couldn't get it to work.
I'm not quite sure where exactly the culprit lies, but i think it is related to Truenas or my config at least..
So, I am aware that running a copper Gbe and Fiber 10Gbe simultanious is not supported.
My switch shows me that the uplink is there (Mikrotik CRS326):
If i swap the leads of the fiber, no lights blink, and 'no link' is displayed, so i'm confident that's not it.
However, my stats page suggests the NAS side isn't transmitting anything:
Normally, in Truenas, 'link state' should be up even if there is no IP, if i'm correct?
But i thought, that should maybe be normal becaus no IP is set?
So i went and deleted the IP form the Gbe interface, applied and copied over on the IX3's interface page. (also tried all other IX interfaces..)
Hit apply changes and test for 60s, but no success.
Also tried pulling out the copper connection from the NAS to the switch, if for what ever reason that could interfere with assigning the address.
Then tried through the command line to get things running or changing the network config, but i'm failing to get results..
ifconfig results below:
I'f i'm not mistaken, "no carrier" means no link.. so either the cable is faulty (checked) or the tranciever is (also checked)..
Fiber is fiber, but trancievers are tricky.
As I read through the plethora of these questions and many suggestions, i bought FS.com trancievers and my desktop and NAS side are running these. The switch side works with either Mikrotik or the Uptimed trancievers.
Desktop runs fine.
How should I proceed to continue to investigate this problem?
Thanks in advance everyone!
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
root@truenas[~]# ifconfig
ix0: flags=8822<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=4e53fbb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
ether 6c:b3:11:65:78:34
media: Ethernet autoselect
status: no carrier
ix1: flags=8822<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 6c:b3:11:65:78:36
status: no carrier
ix2: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether d0:50:99:fe:5b:3b
status: no carrier
ix3: flags=8c22<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether d0:50:99:fe:5b:3a
status: no carrier
igb0: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=4a120b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWFILTER,RXCSUM_IPV6,NOMAP>
ether d0:50:99:fe:5b:3c
inet 192.168.1.33 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8822<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=4e527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
ether d0:50:99:fe:5b:3d
status: no carrier
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x7
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
ue0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 6e:7f:8a:e9:cd:93
ether 58:9c:fc:10:39:17
member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 12 priority 128 path cost 2000
member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 11 priority 128 path cost 2000
member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 20000
groups: bridge
vnet0.1: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: PlexJail as nic: epair0b
options=8<VLAN_MTU>
ether d2:50:99:3d:c3:2d
hwaddr 02:ad:79:de:36:0a
groups: epair
status: active
vnet0.2: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: adguardhomeJail as nic: epair0b
options=8<VLAN_MTU>
ether d2:50:99:76:4d:54
hwaddr 02:38:e3:62:b7:0a
groups: epair
status: active
vnet0.3: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: syncthing as nic: epair0b
options=8<VLAN_MTU>
ether d2:50:99:5b:07:f8
hwaddr 02:f3:99:cc:93:0a
inet 172.16.0.1 netmask 0xfffffffc broadcast 172.16.0.3
groups: epair
status: active
nd6 options=9<PERFORMNUD,IFDISABLED>I'f i'm not mistaken, "no carrier" means no link.. so either the cable is faulty (checked) or the tranciever is (also checked)..
Desktop runs fine.
