10Gb performance issue, 350Mb/s tops
dtom10
Hello all,
I'm seeing a weird issue with my 10Gb adapters that I don't really know how to debug.
I have the following setup:
On Freenas I have an Intel X540-T2 adapter linked directly to my desktop using a good quality 10m CAT6e cable. The desktop uses the Intel X550 adapter onboard the Asus X99-E-10G WS
Testing with iperf results in a maximum performance of roughly 350Mbytes/s. On the desktop i have upgraded to the latest driver without seeing any performance improvement, desktop OS is Win10. SMB performance is ~330Mbytes/s
Here's the raw data:
Freenas side
root@ssdnas# iperf -s -f M
Server listening on TCP port 5001
TCP window size: 0.12 MByte (default)
[  4] local 192.168.1.200 port 5001 connected with 192.168.1.10 port 53036
[ ID] Interval	   Transfer	 Bandwidth
[  4]  0.0-10.0 sec  3558 MBytes   356 MBytes/sec
Desktop side
bin/iperf.exe -c 192.168.1.200 -P 1 -i 1 -p 5001 -f M -t 10
Client connecting to 192.168.1.200, TCP port 5001
TCP window size: 0.06 MByte (default)
[304] local 192.168.1.10 port 53036 connected with 192.168.1.200 port 5001
[304]  0.0- 1.0 sec   357 MBytes   357 MBytes/sec
[304]  1.0- 2.0 sec   353 MBytes   353 MBytes/sec
[304]  2.0- 3.0 sec   357 MBytes   357 MBytes/sec
[304]  3.0- 4.0 sec   356 MBytes   356 MBytes/sec
[304]  4.0- 5.0 sec   354 MBytes   354 MBytes/sec
[304]  5.0- 6.0 sec   355 MBytes   355 MBytes/sec
[304]  6.0- 7.0 sec   357 MBytes   357 MBytes/sec
[304]  7.0- 8.0 sec   357 MBytes   357 MBytes/sec
[304]  8.0- 9.0 sec   354 MBytes   354 MBytes/sec
[304]  9.0-10.0 sec   358 MBytes   358 MBytes/sec
[304]  0.0-10.0 sec  3558 MBytes   355 MBytes/sec
Done.
Driver & ifconfig
ix0: <Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.1.13-k> mem 0xfaa00000-0xfabfffff,0xfa9f0000-0xfa9f3fff irq 17 at device 0.0 on pci1
ix0: Using MSIX interrupts with 9 vectors
ix0: Ethernet address: a0:36:9f:1f:e1:00
ix0: PCI Express Bus: Speed 5.0GT/s Width x8
root@ssdnas# ifconfig ix0
ix0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=e407bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
		ether a0:36:9f:1f:e1:00
		inet 192.168.1.200 netmask 0xffffff00 broadcast 192.168.1.255
		media: Ethernet autoselect (10Gbase-T <full-duplex,rxpause,txpause>)
		status: active
Freenas system:
Intel Xeon CPU E3-1265L V2 @ 2.50GHz
16Gb ECC DDR3
4 X 525Gb Crucial MX300 Raid Stripe
FreeNAS-11.0-U4 (54848d13b)
Any help is greatly appreciated.
dtom10
Doesn't look like a match. For starters it's not the same card, mine's tied to ixgbe. There are no network cuts only the performance. For example, the smb copy of an 8Gb .iso file runs peak at around 320Mb/s, no dips or rises. Looks like there's something capping the speed.
Stux
Possible a low speed quad core doesn't have enough oomph for more than 3.5gbps.
Silly L chips.
What's you CPU utilization during the iperf, and have you run it in both directions?
dtom10
I thought iperf does not bother disks with nuisance. The system is idle. It's not doing anything else. At work I have lower speed xeons with dual 10Gb cards. I would think that the cpu is not the bottleneck here.
last pid: 79901;  load averages:  0.25,  0.11,  0.03																																   up 0+02:31:59  23:44:04
56 processes:  1 running, 55 sleeping
CPU:  0.2% user,  0.0% nice,  1.9% system,  3.2% interrupt, 94.7% idle
Mem: 146M Active, 457M Inact, 4332M Wired, 11G Free
ARC: 990M Total, 90M MFU, 606M MRU, 160K Anon, 40M Header, 254M Other
Swap: 8192M Total, 8192M Free
  PID USERNAME	THR PRI NICE   SIZE	RES STATE   C   TIME	WCPU COMMAND
79667 root		  4  20	0 26488K  3444K uwait   5   0:09  16.41% iperf
LE: tried both, on the the desktop i'm using jperf
Spearfoot
He of the long foot
Try using jumbo frames.
dtom10
Did that when I've set it up, the SMB speed was ~190Mb/s :(
Hello all,
Freenas side
Desktop side
Done.
Driver & ifconfig
		status: active
Freenas system:
16Gb ECC DDR3
Which version of iperf? If iperf 2.0.10 you can use -e on a unix client to get TCP RTT and CWND samples
Spearfoot
He of the long foot
Stux
Me too, and that's a 2.2ghz Xeon. It might've been ESXi too.
dtom10
Ok, this being a fresh install and not having to worry about data loss I went on to install a Centos 7 linux on the systemboot hdd. I wanted an unconstrained environment on which to test all sorts of settings and install whatever test software i needed.
What I have found is that indeed. @Spearfoot is right, enabling jumbo frames got me ~560Mb/s of performance instead of the previous ~350Mb/s that I got with defaults. The next thing that got me close to the full speed were the rx/tx ring buffers which came with a default of 512k from the 4096k max. Setting those to max on the desktop and the server produced roughly 8.1Gbits/s testing single transfer one way with iperf3 sending data from my win10 desktop to the Centos based install.
Apparently the same settings in FreeNAS produce the same results so I'm a happy camper :)
MTU is set to 9014 because that's what the desktop card is reporting.
Since FreeNAS embeds iperf2 i used jperf2.0.2 on my desktop
304] local 192.168.1.10 port 52736 connected with 192.168.1.200 port 5001
[304]  0.0- 1.0 sec  1017 MBytes  1017 MBytes/sec
[304]  1.0- 2.0 sec  1002 MBytes  1002 MBytes/sec
[304]  2.0- 3.0 sec  1011 MBytes  1011 MBytes/sec
[304]  3.0- 4.0 sec  1049 MBytes  1049 MBytes/sec
[304]  4.0- 5.0 sec  1048 MBytes  1048 MBytes/sec
[304]  5.0- 6.0 sec  1041 MBytes  1041 MBytes/sec
[304]  6.0- 7.0 sec  1045 MBytes  1045 MBytes/sec
[304]  7.0- 8.0 sec  1078 MBytes  1078 MBytes/sec
[304]  8.0- 9.0 sec   996 MBytes   996 MBytes/sec
[304]  9.0-10.0 sec  1088 MBytes  1088 MBytes/sec
[304]  0.0-10.0 sec  10375 MBytes  1037 MBytes/sec
Done.
One more question, is editing the /boot/loader.conf a supported action or we are not supposed to touch that file. I'm planning on setting some sysctls in there to see if I can take the card to its max throughput.
SweetAndLow
Sweet'NASty
Done.
You set sysctls in the GUI not the cli.
dtom10
Right, the tunables section I presume?
One note to add is that the options for the network interface should not contain that equals sign, replace equals with space. I'm assuming it's an UI bug that accepts the equals sign or a feature gap (e.g.: convert equals to space).
