Sunppj
 - Jan 31, 2020
При создании виртуальной машины выдаёт ошибку:
[EINVAL] vm_create: This system does not support virtualization.
Подробнее:
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
io_thread=False)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1077, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.7/site-packages/middlewared/service.py", line 396, in create
f'{self._config.namespace}.create', self, self.do_create, [data]
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/vm.py", line 804, in do_create
verrors.check()
File "/usr/local/lib/python3.7/site-packages/middlewared/service_exception.py", line 62, in check
raise self
middlewared.service_exception.ValidationErrors: [EINVAL] vm_create: This system does not support virtualization.
Подскажите пожалуйста как вылечить.
Подробнее:
io_thread=False)
verrors.check()
raise self
