Register for the iXsystems Community to get an ad-free experience
Resource icon
Transmission Jail setup with OpenVPN and DNS Leak protection
Note: this guide is complementary to many guides on how to setup Transmission with OpenVPN, hence it assumes you have already followed those guides and you are just looking for some extra security protection
Problem
Case 1 :
Your OpenVPN client refuses to use your VPN Provider's DNS server hence you resort to all sort of tricks to ensure your normal DNS server is not exposed while you are on VPN.
Case 2 : You use OpenVPN client to secure your Jail's traffic via your favourite VPN provider, but when you run the following command your ISP DNS shows up !! Your DNS queries are leaking
# iocage console <<your transmission jail with OpenVPN >>
# drill google.com
;; ->>HEADER<<- opcode: QUERY, rcode: NOERROR, id: 23327
;; flags: qr rd ra ; QUERY: 1, ANSWER: 1, AUTHORITY: 4, ADDITIONAL: 0
;; QUESTION SECTION:
;; google.com.    IN    A
;; ANSWER SECTION:
google.com.    11    IN    A    216.58.212.174
;; AUTHORITY SECTION:
google.com.    41496    IN    NS    ns4.google.com.
google.com.    41496    IN    NS    ns2.google.com.
google.com.    41496    IN    NS    ns3.google.com.
google.com.    41496    IN    NS    ns1.google.com.
;; ADDITIONAL SECTION:
;; Query time: 34 msec
;; SERVER:   XXX.XXX.XXX.XXX      <<-<-<-<- YOUR ISP's DNS HERE !!
;; WHEN: Mon Nov 23 21:00:46 2020
;; MSG SIZE  rcvd: 116
Solution Overview
  • Step 1: Enable OpenVPN service to run at security level 2
  • Step 2: Customise the ready-made "openvpn-client.up" & "openvpn-client.up" scripts that do the DNS configuration for you
  • Step 3: Setup your OpenVPN client config to use the DNS config scripts
  • Step 4: Restart your OpenVPN service and check the DNS used
Step 1: Change OpenVPN service to run at security level 2
Console into your jail and Open your rc.conf
# iocage console <<your transmission jail>>
# nano /etc/rc.conf
Paste the below line in the file, press Ctrl+X and save.
openvpn_dir="/usr/local/etc/openvpn"         # this is where we'll copy the up/down scripts
openvpn_flags="--script-security 2"             # allow .conf to invoke DNS setting scripts
Exit your jail and restart for the settings to take effect
# exit
# iocage restart <<your transmission jail>>
Step 2: Move the DNS setup scripts in place
Copy the DNS setup scripts onto the OpenVPN config directory and grant them exec rights
# cd /usr/local/etc/openvpn/
# cp /usr/local/libexec/openvpn-client.* .
# chmod 500 openvpn-client.*
The files should look something like this
# ls -la
drw-------   3 root  wheel    11 Nov 23 18:53 .
drwxr-xr-x  19 root  wheel    29 Nov 23 19:14 ..
-r-x------   1 root  wheel  1755 Nov 23 18:44 openvpn-client.down
-r-x------   1 root  wheel  2982 Nov 23 18:45 openvpn-client.up
Open openvpn-client.up and add the following line before the "exit 0" statement.
This will ensure your ISP DNS is removed, keeping only your VPN provider's DNS while the OpenVPN is active
echo -n nameserver <<your ISP DNS>> | resolvconf -d epair0b
exit 0
Open openvpn-client.down and add the following line before the "exit 0" statement.
This will ensure your ISP DNS is put back while your VPN provider's DNS entries are removed once OpenVPN goes down
echo -n nameserver <<your ISP DNS>> | resolvconf -a epair0b
exit 0
Step 3: Setup your OpenVPN client config to use the DNS setup scripts
Add the following two lines at the top of the openvpn config file, press Ctrl+X and save
up openvpn-client.up
down openvpn-client.down
Your config file should look like this ...
client
dev tun
proto udp
; Cert
remote-cert-tls server
cipher AES-256-CBC
Restart your openvpn service for the settings to take effect
# service openvpn restart
Once the service is back you should be able to see only your VPN providers DNS servers
# cat /etc/resolv.conf
# Generated by resolvconf
nameserver <<VPN Provider DNS1>>
nameserver <<VPN Provider DNS2>>
Similarly stop the OpenVPN service
# service openvpn stop
Once the service is down you should be able to see back your ISP's DNS server
nameserver <<ISP DNS Server here>>
Author
FreeVel
Views
266,249
First release
Last update
Rating
5.00 star(s) 3 ratings
Latest reviews
Thank you for this. Just found this article and resolved my issue.
Just what I needed. Amazing stuff! Thank you!
Brilliant, brilliant, brilliant. I set up OpenVPN as per many online instruction and discovered my DNS queries were still going via my ISP. I couldn't work out why (maybe because I have a separate Pi Hole local DNS server set up that was still dealing with all LAN DNS requests - including my jail even with OpenVPN up and running). Anyway this guide fixed the issue. Resolv.conf now points to the VPN DNS server when OpenVPN is running and my local Pi Hole DNS server when down - exactly as I wanted. Thank you for this....
